Use voltage divided instead of external battery with a scr
ElectricSpidey
Joined Dec 2, 2017
3,359
I don't see the point of triggering the SCR from the 12 volt side if the module is isolated, I would just trigger the SCR from the 200 volt side and keep the isolation. (with the proper resistor)
Also, the idea to place the power switch on the 12 volt side is a good one. (from post #19)
Edit:
After thinking about it I guess if the OP wants to use the entire range of the booster it would not be possible to find a single resistor to do the job. But from 200 to 390 would be possible.
