Use generic portable console LCD screen on a DIY project?
spikespiegelbebop
Joined Nov 30, 2021
163
So I was wondering... there is this device on sale online and I thought it would give a nice raspberry pi project:
But I wanted to check here first if anyone know about some type of microcontroller for the device' screen. Since it's a generic video game console and I'd like use a raspberry pi with its screen, it means that I'd have to discard the original circuit and use one that could convert a hdmi signal to be displayed on the screen, it would obviously have to feed the screen, with a power supply, too.
In shortly, I'm just wondering if there's a way to connect a raspberry pi to this device screen.
Specs
Brand name: albabkc
Resolution: 960x480
There are others too, like:
MIYOO MINI V2 and Nova X20mini handheld.
EDITED: As requested, here are the links of the consoles that I'm talking about:
Check this one first
https://www.aliexpress.com/item/-/1005003663790556.html
https://www.aliexpress.com/item/-/1005004371411259.html
https://www.aliexpress.com/item/-/1005004508486973.html
https://www.aliexpress.com/item/-/1005003408758563.html
bassbindevil
Joined Jan 23, 2014
924
For about $20 you can buy an LCD screen that's compatible with Arduino and/or Pi. Converting from HDMI to LCD will cost more, more than a complete used LCD TV or monitor.
Now, that handheld game console is probably running something like Linux, so there may be Rx/Tx pins to connect over serial. I can't be bothered to watch the video and see if gets into stuff like that.
spikespiegelbebop
Joined Nov 30, 2021
163
It's not just the screen that interests me, the housing too, as I need both the screen and the housing for the project. And judging by the size of the screen, it's way cheaper to just buy this console and then try using a raspberry pi inside. I just need a way to connect the raspberry pi to the screen. Take a look at the video, it's a short video and you can skip to the parts that will interest you. There's a part where he says that the TFT display is a generic LCD display. If that's a generic LCD display, there must be a microcontroller somewhere for it, or a pcb to directly connect the raspberry pi through GPIO, or at least a datasheet/service manual for the screen.
BobTPH
Joined Jun 5, 2013
11,639
There is no telling whether the display has a standard interface or is directly controlled by a custom single chip micro. If it is the latter, there is not much hope for using it.
spikespiegelbebop
Joined Nov 30, 2021
163
Yeah you're right. I was just hopping that I could find some info here. Anyway, it will be cheaper for me even if I just "recycle" the housing, because I found the entire device, brand new, for $8.67 on sale. As for the firmware, it really needs to be something with a raspberry pi zero, that's just not a gaming console, it's also a cryptocurrency wallet, and I he firmware only works with the raspberry pi as far as I know. Reference: https://www.pitrezor.com/2018/02/pitrezor-homemade-trezor-bitcoin-wallet.html
Utilize the housing and sell the rest.
