hi everyone, i was wondering how can i convert usb type c cable to have one side of cable to be usb type c and the other side a simple normal two wire red for positive and black for negative; do i need controller for this ?
The position of negative-positive in all USB including mini-USB, micro-USB, type A, type C are the same whatever you call it..they are position at the same place ...but unfortunately the color code is not universal...so don't think the red always positive and black is negative or it can be any other color.
Plug in the USB to a power source and use your multimeter (DC voltage) and measure the voltage you will if your volt meter show negative voltage you are connecting it to the wrong wire...then exchange once you see positive voltage u are correctly measuring the correct positive-negative wire of the USB.
