Yet good tools help you grow.Let me reiterate my criteria:
Audio: a few kHz is plenty.
Signal generator would be useful.
2 channel.
I’m a mechanical engineer, I can’t imagine I’ll ever use most of the features on the newest model. But I appreciate that the cost diff between a SDS12xx is not much more than the 1000 series or even other brands.
It comes with 1 passive probe per channel. Will that be sufficient for my needs?If selecting a new low cost DSO for personal needs, SDS802X HD @$340 cannot currently be surpassed as providing best bang for buck.
As opposed to what?It comes with 1 passive probe per channel. Will that be sufficient for my needs?
Just as any other new scope.It comes with 1 passive probe per channel.
Maybe not, certainly for advanced use additional specialised probes can be required.Will that be sufficient for my needs?
Typically digital transfer uses one of the common protocols, UART/RS232, SPI, I2C etc.I also saw digital probes. My tuner project currently uses ADC, but I’m hoping I can transition to digitalRead(). Wondering how a digital probe would work.
An example using just 4 of the 16ch available of the $ digital probe assembly with SDS800X HD is here:I also saw digital probes. My tuner project currently uses ADC, but I’m hoping I can transition to digitalRead(). Wondering how a digital probe would work.
Yes in just a few years, my how scopes have advanced and some might even call their feature set extreme, however one should never overlook that a scope is a scope is a scope, they all have s/div and V/div adjustments and trigger level settings, but due to the way a DSO samples signals, trigger capability is now your most powerful tool and allows capture of infrequent events that won't even show on a CRO.@tautech thanks for the info and links. I’ve been reading through a lot of that today, digital anything and DSOs are a whole new world for me, will take some time to assimilate.
The SDS800 is fairly new, but you content it is by far the best at its price point. And the 804 for another $100 over the 802 would give me more digital flexibility should I need it, not to mention just more channels at the same time. Thanks
You will love it.Thanks for all the help and suggestions. I bought a Siglent SDS804x HD today, using the eevblog discount. I had no intention of spending $400, but after a lot of research and consideration felt that it is a better value than the cheaper $150-250 scopes. Even 4ch vs 2ch, @sarahMCML and the eevblog guy convinced me how useful 4ch can be. I'm a novice, I'll never use it to it's full potential, but I do hope to learn and grow and become somewhat proficient with it. I'm really hoping it can help me further my understanding of electronics and circuit design... more so than I can now with my CRO. I've got 2 projects right now that I need to utilize a DSO to help me make them better: a guitar tuner and a pretty sophisticated acoustic guitar preamp/EQ.
Anyway, thanks again. I'll pop back in a week or so after I get my first successful trace.
When recieved, check the firmware installed is the latest and if not update with this:Thanks for all the help and suggestions. I bought a Siglent SDS804x HD today, using the eevblog discount. I had no intention of spending $400, but after a lot of research and consideration felt that it is a better value than the cheaper $150-250 scopes. Even 4ch vs 2ch, @sarahMCML and the eevblog guy convinced me how useful 4ch can be. I'm a novice, I'll never use it to it's full potential, but I do hope to learn and grow and become somewhat proficient with it. I'm really hoping it can help me further my understanding of electronics and circuit design... more so than I can now with my CRO. I've got 2 projects right now that I need to utilize a DSO to help me make them better: a guitar tuner and a pretty sophisticated acoustic guitar preamp/EQ.
Since you already (probably) have probes and certainly have a computer, you might look at the Espotek Labrador ( espotek.com )"lab on a chip." Two channel scope, function generator, logic analyzer, VOM, Spectrum analyzer and lots of fun. Not a "serious contender" to my 200 mHz "big rig," but for ~ $30, it might do what you want. If not, within hardware limits, take advantage of its open source and "roll you own." Chris, the founder and manager ( info@espotek.com ) gives prompt and expedient help.I've been using a Tek 2213 for a while now. Ch1 works ok, ch2 doesn't. I've been looking at upgrading for <$100. I use it for audio stuff, low frequency, a few kHz is all I need.
Hantek 6022be Digital Oscilloscope is only $65, 20 Mhz.
Are there other USB based to consider? A stand-alone would be nice but decent digital ones are hard to find for <$300.
Thanks.
OK. Updated the firmware, although curious the instructions weren't in 1.1.3.8. I had to go back to 1.1.3.6 to find the instructions. Also hooked up a mouse.You may find this initial setup guide useful:
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5577481/#msg5577481
