USB hub 2 to 1 circuit
david1234
Joined Nov 27, 2013
104
Hello ,
I want to build a USB splitter
so I will be able to connect 2 usb devices to my computer
something like 2 USB camera for example
I have try to connect all the cables together but it will only show me 1 usb device
how do i do this?
Thanks ,
ScottWang
Joined Aug 23, 2012
7,505
Ar you using two usb devices at the same time?
If they are not using at the same time then you can use the switches to built it.
A lot of usb hubs in the market, why you want to build your own?
david1234
Joined Nov 27, 2013
104
I need to build a IC board
and I need to connect it to a computer with only 1 USB port
and in my board I have 2 usb device that need to be connected
david1234
Joined Nov 27, 2013
104
I need \ want it to be on my circuit as
I dont want to add external device
so in the end i will have a circuit that know how to do it
can't be that hard....
