USB card reader to memory
Status
Not open for further replies.
thomaswally
Joined Mar 22, 2011
4
Hi im not very good at this so im looking for a little help to point me in the right direction
i have a USB magnetic card reader and and i was wondering how i can hook a usb or sd card up to it so its standalone
i was thinking maybe run it through an Arduino board ?:confused:
or maybe theres something easier ?
thanks in advance
tom66
Joined May 9, 2009
2,595
What do you intend to do? Interface a USB device with an Arduino?
You might have luck with the Uno and its new USB chip, but the older ones aren't going to be as easy, if even possible.
thomaswally
Joined Mar 22, 2011
4
thanks for the reply
that seems a bit to hard
is there a way that info that is read from the reader can be saved straight to some sort of memory ?
GetDeviceInfo
Joined Jun 7, 2009
2,289
thanks in advance;)
do you have all the information required to command the reader? Hardware is not a problem as there are numerous offerings. What will be the problem is if you have all the documentation required including command codes.
GetDeviceInfo
Joined Jun 7, 2009
2,289
being a card kind of guy, I am compelled not to assist you, just in case you end up with one of my cards in your hands. In fact, I can tell you that something like this is WAY over your head.
beenthere
Joined Apr 20, 2004
15,819
Every magnetic card reader has its output completely described. You can work with that to learn how to do what you wish. Or perhaps you can find a cookbook solution elsewhere.
It's hard to see a positive motivation for this interest.
Status
