- Joined Jan 23, 2018
- 28,600
Certainly a volt meter is able to verify presence of a voltage if it has an adequate pair of connections.
UNLESS, of course, it is a one terminal voltmeter that simply senses voltage.
My probe uses me as a reference and indicates any AC voltage above about 70 volts.
AND I routinely check the circuits I will be working on to verify that they are live before I switch the circuits off. So it gets tested at every use. It is not like one of those toy test devices found in discount stores.
