US Bauer battery charger on 50hz?
dcastor76
Joined Feb 11, 2021
I am planning a move to Germany and plan to bring a Bauer Li-ion cordless drill with me. The charger indicates it needs 120V 60Hz, so I know I need to use a transformer, but should I expect any issues with running it on 50Hz vs 60Hz?
AlbertHall
Joined Jun 4, 2014
12,663
If the charger uses a transformer directly from the input voltage there might be a problem.
If it uses a switch mode supply inside then there will be no problem with the frequency.
