I changed all MOSFETs in parallel and they burnt again. I AM SO TIRED, IVE WASTED MORE THAN 20$ for this UPS:'( The gate Resistance is 24ohms, I will try increasing it and check again.
If the FETs are not turning on adequately that could be the problem. So now another question: Did this UPS EVER perform correctly, and deliver at least 100 watts into some load for a few minutes without burning up?I changed all MOSFETs in parallel and they burnt again. I AM SO TIRED, IVE WASTED MORE THAN 20$ for this UPS:'( The gate Resistance is 24ohms, I will try increasing it and check again.
How did you test the diodes and caps? In circuit? Did you use a tester designed specifically for diodes and caps?it had 2 originally, and one open space to add another FET. all diodes and capacitors are fine.
This is what I was saying in post #3.If the FETs keep burning out then something else is wrong. Don't change values from the original design yet, it's unlikely in a commercial product that the original design is so bad that it will die right away. It is more likely that something else has broken in the circuit which is causing the fets to burn out. The fets are the symptom, you haven't found the actual problem yet. Keep looking for other bad parts or connections.
Not only did you reduce the load on the FETs by half, but in addition, by making a separate circuit board and connecting it you probably corrected some other problem, possibly the parasitic oscillation at some very high frequency, or some failed connection that your modification repaired. But the good point is that you have it working again.OK. something strange happened. I increased gate Resistance and then made another Circuit board for the MOSFETs to be in parallel, they are working perfectly generating less heat than the others(I increased from 2 to 4 Power FETs ), which is strange, because all of the FETs now get a little warm instead of heating up. It looks like all the load was being pushed to Only ONE MOSFET, but I don't know why .
There are several different schemes for producing an alternating 120 volt AC output. Many of the simplest UPS packages us a driven inverter with the primary input fed directly from the battery supply. The drive is an on/off signal with a dead time in between, so that it is sort of equivalent to a sine wave effective power. Some others use a much higher PWM signal to come closer to an effective sine-wave equivalent. Those devices are switching at a much higher frequency. Probably your lower price system uses a driven inverter version.And another question. Do Inverter MOSFETs switch at 50hz or 100hz? Or at what frequency?
Turning 1 LED on and another off - I can't seem to make this schematic work. | General Electronics Chat | 17 | |
| Y | Help turning a Falstad LM324 voltage monitor into a 40 × 100 mm PCB layout | Homework Help | 3 |
