UPS design
bassbindevil
Joined Jan 23, 2014
924
LOAD is just whatever you power from it.
It looks like the cells you're getting are normal lithium-ion. The fact that they have tabs already spot-welded to them suggests could be new surplus. Or they could have been rejected for being under-spec, or counterfeit. They resemble the real ones tested here, but I don't see the faint QR code marking, or date code stamps, so it might just be a good fake wrap. I'd be inclined to order one or two to test, unless you have some independent assurance that they're good. The different look might just be normal production variations.
https://lygte-info.dk/review/batteries2012/Panasonic NCR18650B 3400mAh (Green) UK.html
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yeah, tanks. I figure it out in the meantime
About the batteries, yeah, tey are probably some fakes. But it doesn't matter. For this purpose I just need tey don't leak or don't catch on fire on their own. If they degrade quickly, I still can use the BMS and the other device for other projects with real cells.
I'm now waiting on thhe items to get from Aliexpress.
Let's see how this will turn out!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hi again.
I just got part of the components and I was trying to discharge some old batteries from a power bank I had here that was not charging (or at least wasn't holding the charge) with those power resistors. I got two of these. One is 5W4Ω and the other one is 5W5Ω.
I try to do it with the 5W4Ω. It got quite hot and at first I saw the batteries discahrging from 3.8V to around 3.2V but then, I measured again and it was measuring 3.71V and was increasing. Don't understand. lol. This was in about 5 minutes.
Now, I'm trying again with the 5W5Ω and it's measuring 3.55V and decreasing! Going to wait for 5 minutes also and see what happens!
Edited;
5 minutes later with the 5W5Ω, the voltage decreased from 3.55V to 3.177V
But the, I removed the resistor and measured again and it's back up to 3.63V and increasing! How is this possible?
Edited 2;
Further, I tried to use P = V*I <=> 5 = 3.72*I <=> I = 1.344A.
However, with the 5W4Ω, DMM shows 0.880A
and with the 5W5Ω, DMM shows 0.660A
I also tried P = R*I^2 for both Rs, giving currents of 1A for the 5Ω and 1.1180A for the 4Ω. Why any of these values match neither with the other Power formula nor with the DMM?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, peeps, I now have enough batteries to build a 4s3p battery. I also have the BMS and the other device (can't remember the name now).
I didn't remember but I had here 4 more batteries, however, they must have lost some charge over time and they are now all at 2.69V.
Is it ok if I use 2 of these cells with the other 10 cells at 3.6V? Will the 2 devices (electronic boards) control the charge of all cells even if they are not at the same voltage?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
@bassbindevil I think I can use cells at different carge level but I wanted to make sure. I expecting the 2 electronic devices to balance the charge needed according to each cell / cell pair, no?
bassbindevil
Joined Jan 23, 2014
924
It's better to charge all the cells to the same level before assembling a pack, although if one bank is low, the balancer should eventually even them out. Also, to test the cells for capacity and internal resistance. For internal resistance, just touch a load resistor (say 4 ohms) across the cell and see how much the voltage drops from open circuit. Capacity requires a smart charger or (much cheaper) a discharge tester (from Ali/Ebay for a few bucks as a board and power resistors).
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Well, I didn't have most of those tools so I just went with assembling the whole stuff. Started by soldering the 3 batteries in parallel and then the 4 rows of 3 parallels in seies. Then I soldered the BMS and all went fine. Then went for the other small module and soldered the BAT- to the BMS LOAD-, then when soldering one of the ends of the LOAD+, one of the BMS transistors simply blew up. The other end of the LOAD+ (on the smaller module wasn't even soldered yet). No idea why this happened.
I'll try to get my hands on a transistor and replace the damaged one and hope that it was only that component that blew up and nothing else. But it will take sometime as I don't have an electronic shop where I live!
Sad day!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
So, I'm searching for replacement transistors for this BMS.
What these have written is A09 N03(N) xxxxxx where the 'x's can be different. For instance, one of the rows are:
A09 N03 EDL3A73, A09 N03 ECC1A52, A09 N03N xxxxxxx, A09 N03N CEK0554 and A09 N03 EDA4A22.
The third one I can't read.
But, from this picture, you guys can help me finding the correct replacement transistor, please?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hello.
I'm back to this project and I've replaced one of the transistors that blew up last time I was soldering the wires from the batteries to the BMS. I have soldered the points 0V, 4.2V, 8.4V, 12.6V and 16.8V. Nothing blew up this time. I still didn't soldered the other module.
However, I'm not sure if the following is normal. I'm measuring from 0V to any of the leads of the transistors and all measure 0V. Is this normal?
I also measured voltage across a few resistors and they also measured 0V. There is only one component that measures the 14.4V which is what it looks to me as a diode.
Is this normal?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hi.
Is there any reason why I can't set more than 180mA of charge current with Iset rpot of the MAX745 module?
I mean, if I start rotating the rpot while I am charging with an external power supply, I can see the current going up but when it reaches around 180mA, the charge current instantly drops to minimum levels like 40mA or so. Then, I have to rotate the rpot back and start rotating it again in the opposite direction to get to the same 180mA again, but can't go over that. Wasn't it supposed to support up to like 2A of charge current?
A 3P4S setup is taking surelly over 16h to charge up from like 15.7V to 16.8V.
And I'm not even sure how to set the charging voltage. Like, am I supposed to set it before connecting the MAX745 module to the battery pack?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Any help on my previous post/question?
The modules are working together and I can use the battery pack. It's just the problem that when trying to adjust the chraging current, I can't make it over 180mA!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Well, after sometime using the battery pack, now, all of a sudden, 3 of the cells are just dropping their voltage to close to 0V and never charge up again, so the battery pack is reading 12.6V instead of 16.8V.
Any possible reason for this to be happening?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Well, I end up disassembling the whole pack because seems that all batteries are reading like 0.2V individually. I think it's time to get rid of these batteries and get new reliable ones!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
What is your load sir?, and what kind of batteries and how many you have?
I had a 3p4s configuration and the batteries were 18650 but bought on Aliexpress!
The battery pack worked for some time, but maybe one of these last weekends I left the battery connected to the load and maybe for some reason the BMS allowed them to discharge below reasonable values and now, all the batteries are measuring around 0.2V.
So, I just disassembled them all and I might try to find 12 new batteries.
The load was a circuit prepared to lower the voltage from 16.8V to around 7 or 8V and then, feed 4 ESP32-cam devices.
The circuit was discussed here, if you're interested.
