Its a pretty straight forward question. My project for my HNC is work based and it involves Changing our PCB's from through hole to Surface Mount. My question is about resistor Power ratings and temperature coefficient.
For example the current through hole resistor, 10K ohms, 200V, 1% tolerance has a power rating of 125mW and temp coefficient of 50ppm/C. I have found an equivelant value resistor that is SM type but its power rating is 250mW and temp coefficient is 100ppm/C.
Will there be any noticable preformance issues if I choose to go with the SM replacement regarding their differences in power rating and temp coefficients? Are there other paramaters to consider when converting like components?
Thanks in advance.
Thanks in advance.
