- Joined Jan 23, 2018
- 28,609
That is true, but if there was a need to do it there is a way to do it right.Even if the voltage is stable, i still think that it's a bad idea to try to compensate for the voltage drop with extra voltage on the psu. An adjustable supply, or one with a "weird" voltage is likely to cost more than the typical 12v psu. That money could be used to buy the correct cable, and problem solved. That's a better solution than overloading a thinner cable.
