Update old analog Ignition scope
bcwrench
Joined Nov 9, 2009
I have an old All-Pro ignition scope that uses direct series connection between the ignition coil and distributor cap as well as between the #1 cylinder plug wire and sparkplug. Each of these connections feeds through a 15.4 M resistor to the inputs of the scope. The primary connection on the coil switched side feeds directly.
Would anyone hazard a guess as to how I would upgrade this thing to use a capacitive input to replace the coil interface and an inductive clamp to trigger input (#1 cyl). I think experimenting with different timing light or tach pickups would suffice for the #1 probe as it is just a sync probe. The secondary connection needs to be calibrated for voltage.
The maker Rite Autotronics in LA is long gone and schematics are non-existent.
