Up Down Counter using JK FF resets to 2 instead of 0
Boreal Knight
Joined Feb 18, 2017
10
We're making a BCD counter that counts from 0 to 9 and 9 to 0 using JK F/F. I'm having trouble resetting from 9 to 0 in the up counter and I'm running out of ideas to fix this.
I followed a certain post here regarding that and I came up with this:
from this
Anyway, the counter seems to be fine if I connect all the reset pins to Vcc. It ends up counting up to HEXF and so forth. The down counter seems fine too. I made a detailed logic gates of the reset pins like this
I don't know what else to do. Been trying to think this and thought the IC was the problem, turns out there was a problem with simulating it too
RBR1317
Joined Nov 13, 2010
715
What is the purpose for resetting FF2 & FF3 when the Q1Q2Q3Q4 counter value is 0000 (RED lines)? Resetting flip-flops that are already reset????
Boreal Knight
Joined Feb 18, 2017
10
I forgot to add the the gates connected to the reset pins are NAND ones. What do you mean by what's the purpose of resetting it during 0000? Should I change something on the gate with ~q1,~q2,~q3, & ~q4?
That's not my point. In the original post, the OP said:
To me that means he's supposed to design a BCD U/D counter using JK flip flops, not T flip flops...
If he "designs" a counter, he won't need to use reset.
So this thing was a T-F/F. I didn't realize it and was weirded out when it used the reset pins. Anyway, I'm trying to make a truth table but it hurts my eyes manually calculating each result from Previous and Next Stage to J K results. IS there any program that makes this somewhat easier?
dl324
Joined Mar 30, 2015
18,502
When you're learning, there are no short cuts. Repetition will make it easier to remember decades from now.
For now, you should develop a technique that minimizes your pain.
