I'm trying to build a simple PWM modulator to convert the analog Audio signal into an PWM waveform, the triangle wave generator works fine and i have used an AC sine wave as an audio input, with an DC offset to match with the Triangle wave reference, but couldn't get the comparator circuit into working, I've seen the same configuration used by some circuits to generate PWM, mainly from "Great Scott" ones. I have also tested the comparator separately without high frequency, and it works fine. and can handle 200khz input with ease, below i have added the images and Spice simulation file. I have downloaded the lm393 spice model from Texas instruments website and its simulation name seems to be lm2901, as they are both similar. but for some reason, the output stays at 0V. Thank you.
