- Joined Jan 23, 2018
- 28,609
So today I hooked everything up as planned, and ran the system. I left the flywheel on the motor, otherwise it had no load. The motor would not start until I had the software running, and the software would not let me start until I plugged in the EKG system. I left the treadmill elevation motor disconnected with no problems.
The console has buttons for "motor start","motor stop", "increase speed", and "decrease speed". Each momentary press of the increase or decrease buttons changes the treadmill speed by .1mph.
The motor is nearly silent, except when changing speed. I compiled a graph of the indicated treadmill speed vs. the rpms obtained from a temporarily installed digital tach. I ran it for an hour at the highest rpm that I am likely to need for this application, and there was essentially no heating of the motor. Of course there was no load.
"motor start" and "motor stop" seem to use programmed gradual acceleration and deceleration. The "emergency stop" button used magnetic braking and stopped it almost instantly. Since there was nobody hooked up to the EKG leads, it would give regular alarms indicating that the patient was dead.
I suppose the next step is to study the schematics (as best I can understand them), and tap into the serial connection between the computer and the drive system box, and see if I can figure out what is going on between them. There is also a service port on the drive system box. I suspect that there are manual speed settings there somewhere.
What I think I see in the photo is a separate box containing the motor driver circuit. I think that I don't see many wires from that enclosed box to the other assembly. But they could also be multi-conductor cables and I could be quite totally wrong. But if there are only a few control wires to the motor drive control then separating it from the rest of the system may not be difficult.
