Unknown Variable_Resistor
mortenlund
Joined Mar 20, 2020
29
Hi all
I have gotten this variable resistor or very large potentiometer. It looks like wire wound with some resistive metal wire of maybe 0.25 - 0.5 mm2 (AWG 24 - 20) exposed in front where a rotating copper plate can conduct. The other sides are covered in some isolating material. It is all on a ceramic ring. Please see attached images.
Does anybody know this product or something similar?
Even not knowing this specific product, I would greatly appreciate any thoughts on its limits in both voltage and current. Any qualified guess is welcome.
Thanks in advance.
Morten
Denmark
Pyrex
Joined Feb 16, 2022
502
Hi, Morten
it seems to me, P250 means the power rating- 250W.
If so, voltage can be found easily : U=sqrt(P*R)= sqrt(250*2000)=707 Volt
Amperage can be found in the same way: I=sqrt(P/R)= 0.35 A
mortenlund
Joined Mar 20, 2020
29
Thank you all. I greatly appreciate your answers. It is a throw out from the electrician company I work in.
Yes it must have been purchased for mains equipment testing - 230 or 400 V.
I plan on using it for eg. testing unknown transformers, using pin 1 for L and pin 3 for N. Then having a variable output between 0 and 230 V. Of course taking into consideration the high ampere that would be possible if testing a low ohm device. Will build a series coupled 0.25 A circuit breaker in to it and attach a thermostat with auto reset on its top side. Then building it into a cabinet with voltmeter and some more.
Just a follow up question, is this setup not much like a vario transformer and well suited for testing eg. unlabeled transformers?
Again thanks for all inputs.
Morten
