I have a Generac Wheelhouse 5500 generator with a B&S 10HP engine. The carburator is held on with a threaded stud, with probably a 1/4-20 thread extending past the carb body to hold the air cleaner. The stud has a Torx like head for screwing into the block, so that means that I need a "reverse Torx" or a "negative Torx" to both remove and screw it tightly in place. Problem is, I have never seen a "reverse Torx" driver, so I have been using a pair of vice grips to remove and install. I don't really want to hog up the ends of the studs, so I would like to get the proper tool.
Does anyone know what this "reverse Torx" tool is called?
