I'm just learning and am using an old digital clock for learning circuit analysis.
The digital clock shows power (LED panel lights almost all the various segments) but will not allow one to set or show the time.
Initially I found two resistors (replaced) which were bad but there is also an unknown inductor that appears open (no continuity).
I downloaded the datasheets for the onboard chip (both TI and Sanyo datasheets as well as someone else's circuit using this chip - all attached) but none show an inductor being used.
Question:
Since the inductor does NOT have a value (just plastic cover in yellow), how do I go about determining the inductors value?
(For example need to hand draw the circuit rather than relying on the datasheets, use some piece of equipment -- my multimeter has Hz)?
Question:
