Unknown compontents (help!)
Tonyr1084
Joined Sep 24, 2015
9,744
Welcome to AAC. Sadly. you're going to need the schematic. Too much of the blown parts is missing for identification. Beyond that - you're also going to need to determine what caused the parts to fail. Unless you find and fix THAT first - simply replacing the components will result in more blown components.
Gi.an.
Joined Dec 14, 2022
7
One is the TEA1522T Switched Mode Power Supply (SMPS) controller IC, but I cannot find the exact [***Y708] you can see on the picture.
For the other one with [65A] I have no clue...
Anyone else?
Gi.an.
Joined Dec 14, 2022
7
After searching I have managed to find for the second one that is probably a diode (65A) from Vishay, acting as a Passivated Rectifier.
And I think 65A is the "ipp - Peak Pulse Current"
Am I right?
