- Joined Jan 23, 2018
- 28,215
Before a cell opens, it reaches a point where it still conducts but runs down much faster than the others.
The TS is powering a 'I connected a 12V 1.4A' FanOr at least a very weak cell.
Not without opening the top of the battery.Just how would I tell which cell is the bad one?
Honestly, I don't know. Perhaps adding a little distilled water maybe ? ? ? I'm really flying in the dark without instrumentation (so to speak).So what would you do, even if you determined which cell is bad?
Overcharging? No. Cells may have dried out from sitting in a hot car over a long period of time. Even though I'd generally charge the unit at least once every four months, they were all pretty dry. There was no fluid level to meter against for fill reference. I filled them to the brim at first, then removed 3/4 inch below the brim, leaving room for outgassing.hi T,
As these are SLA cells, were there any signs of venting due to say past over charging.?
When topping up what fluid level did you take as a reference.?
If you overfill with gel/water and reseal you may encounter vent blow outs if you have not left enough 'gas' space inside each cell, take care.!
E
It's not going to recover if you keep over discharging. Even deep discharge batteries are only specified for a depth of discharge of around 50%.Will this battery fully recover? Time will tell.
Since there is an apparent shorted cell, that would seem highly unlikely.Will this battery fully recover?
