uneven tube bias with el34
Skylar Coy
Joined Apr 29, 2017
133
I have two el34's in ultralinear operation. The resistance from the center tap on tube 1 is 72.4 and on tube 2 it is 83.4. V drop from center tap to plate on both tubes is 2.8. This leaves me with plate currents of 38 and 34. The tube biased lower has much less glow to it compared to the right why is this and how do i fix it.
35,177
Can you post a circuit diagram?
35,177
Try interchanging the two tubes.
Moving the tubes in and out of the sockets could help clean up the contacts.
If the same tube is glowing much less maybe it is time for some new tubes.
35,177
Oh, I see now. You are measuring the DC resistance of the transformer and using that to determine plate current via I = V/R.
I have never seen anyone do that.
BR-549
Joined Sep 22, 2013
4,928
And idle current of 38 ma in one and 34 ma in the other, I would think the filaments are ok.
A ~ 10% difference.
Most tube circuits have wide tolerances. It was just a drive by comment on the tube glow.........I haven't been keeping up on your project or mods.
