uneven series fed antenna array question
yef smith
Joined Aug 2, 2020
1,481
Hello i have a series fed antenna array as shown below.
as you can see by the far field all the patches are fed with the same voltage value.
also when i looked at the e-field cut plane i saw the same efield pattern at the feeding of the patch.
I know that that this series fed array acts as a voltage divider from the excitation source.
how can i change a series feeding of this array so i could control the voltage going into the array?
Thanks.
