Simulation suggests not.Could it function as a current limiter?
Very helpful, many thanksIt’s an ideal diode circuit.
https://www.diodes.com/assets/Datasheets/DZDH0401DW.pdf
It comes from an existing CanBus networking board that attaches to a Raspberry Pi. The 5v_GEN on the left comes from a step down power circuit and 5v output is used to power up the Pi.So where did you find this circuit?
How so?You have Q1 drawn as a N channel.
The original circuit will block reverse current even if there is voltage on the left side.What is the advantage of the original circuit in this thread (using the ideal diode) compared to the one shown here ?
Thanks - I'll stick with the design thenThe original circuit will block reverse current even if there is voltage on the left side.
The simple one won't.
