The Electrician
- Joined Oct 9, 2007
- 2,986
For another example of just how negligible the leakage of a capacitor is, I measured a 4700 uF electrolytic.
The measured leakage resistance was 300 kΩ (100 μA with 30 volts applied), and the measured series resistance at 50 Hz is about 45 mΩ.
Yet, when I measure the parallel AC resistance at 50 Hz, the measured value is 11.4 Ω.
The 45 mΩ series component transforms into about 98 Ω of parallel loss, which is negligible compared to the measured total parallel loss resistance of 11.4Ω. And, the parallel loss component due to the leakage resistance of 300 kΩ is completely negligible.
Clearly, there is something besides leakage resistance, or the transformed series resistance, causing a parallel component of loss. It's the AC losses at 50 Hz in the dielectric.
The conclusion is that if the capacitor is carrying ripple current, and is of good quality, the DC leakage resistance is a negligible component of the parallel loss resistance, so we don't care what the DC loss is when there is ripple current.
This is not to say that leakage resistance is not sometimes significant, but in ordinary power supply filtering use, which is where we usually care about ESR, the leakage resistance is not significant, and doesn't contribute materially to the measured parallel loss component.
The parallel loss component is a significant part of the measured ESR at low audio frequencies, and (in a quality capacitor) is primarily due to the (AC) dielectric loss.
