I have installed 24V tape LED lighting under my kitchen cabinets. I am using a 200W power supply because I am also installing magnet switch operated in cabinet lighting.
The issue is with the power supply plugged in, my Delta Touch2O faucet will not work when touched. I have tried relocating the power supple as far away from the faucet as possible (about 10 ft). The faucet works as designed with the power supply unplugged. The power supply for the faucet solenoid is 6 AA batteries. I have found that if I hold the plastic battery pack in my hand the faucet works. I have tried using tin foil as a Faraday cage around the battery pack, solenoid and the LED power supply, none of these helped. I have also wrapped the plastic battery pack with tin foil and then with none insulated wire and grounded. This seemed to work but not consistently.
Any ideas? I can't be the only one who has had this problem.
