I want build an ultrasonic cleaner machine with at least 600 Watt, but I`m not an expert in electronics and that´s the reason beacause I need your Help.
The cleaner machine would be able to work with frequencies to 60Khz, in particular i`m interested in 28 Khz, 33 Khz, and 45 Khz.
In internet I found a projecct for a radio transmitter I`m thinking it can be usefull for my project.
The ultrasound-piezo.tranducer have an impedance between 10 and 20 Ohm and 60 Watt.
What have i to modify in the project here below to be able to drive my ultrasound transducers?
To generate ultrasound in the right frequency I will use a DSS function generator to produce a square wave so that it can be amplified.
I thank you if you decide to help me
Here are the schematic and the part list:
Parts list.
PART: IC1 TYPE: HEF4001 QTY: 1 SUPPLIER: Farnell PART No: 384434
PART: IC2 TYPE: HEF4017 QTY: 1 SUPPLIER: Farnell PART No: 384720
PART: IC3 TYPE: HEF4538 QTY: 1 SUPPLIER: Farnell PART No: 384630
PART: IC4 TYPE: HEF4013 QTY: 1 SUPPLIER: Farnell PART No: 386339
PART: IC5 TYPE: TC4426 QTY: 1 SUPPLIER: Farnell PART No: 295024
PART: IC6 TYPE: HEF4023 QTY: 1 SUPPLIER: Farnell PART No: 384847
PART: IC7 TYPE: 7812 QTY: 1 SUPPLIER: Farnell PART No: 413215
PART: Q1,2,3,4 TYPE: IRFP450 IR QTY: 4 SUPPLIER: Farnell PART No: 355665
PART: Alternative TYPE: IRFP450 Harris QTY: 4 SUPPLIER: Arrow PART No: 409356F
PART: Q5 TYPE: IRFP260 QTY: 1 SUPPLIER: Farnell PART No: 438522
PART: Q6 TYPE: BF393 QTY: 1 SUPPLIER: Farnell PART No: 933636
PART: Q7 TYPE: BF245A QTY: 1 SUPPLIER: Farnell PART No: 352044
PART: D1,D2 TYPE: IN4936 QTY: 2 (10) SUPPLIER: Farnell PART No: 366950
PART: D3,4,5,6 TYPE: 1N4006 QTY: 4 (10) SUPPLIER: Farnell PART No: 365257
PART: Hall effect TYPE: OHN3040U QTY: 1 SUPPLIER: Farnell PART No: 405656
PART: BR1,BR2 TYPE: 35A 600V QTY: 2 SUPPLIER: Farnell PART No: 234151
PART: LED TYPE: HE red QTY: 1 SUPPLIER: Farnell PART No: 637087
PART: Washers TYPE: TO3P Heat pad QTY: 4 SUPPLIER: Farnell PART No: 936753
PART: RL1 TYPE: 12V coil QTY: 1 SUPPLIER: Arrow PART No: 429052G
PART: C TYPE: 10,000/100 QTY: 2 SUPPLIER: Arrow PART No: 039366H
PART: Clip for C TYPE: 51mm QTY: 2 SUPPLIER: Arrow PART No: 013112C
PART:C TYPE: 22,000/25 QTY: 1 SUPPLIER: Arrow PART No: 091958F
PART: Clip for C TYPE: V3/H2 QTY: 1 SUPPLIER: Arrow PART No: 013013R
PART: C TYPE: 100u/200V QTY: 1 SUPPLIER: Farnell PART No: 699007
PART: C TYPE: 1u/63 QTY: 2 SUPPLIER: Farnell PART No: 228710
PART: C TYPE: 100nF QTY: 10 SUPPLIER: Farnell PART No: 545892
PART: C TYPE: 10uF/25 QTY: 1 SUPPLIER: Farnell PART No: 920502
PART: C TYPE: 100uF/25 QTY: 1 SUPPLIER: Farnell PART No: 698568
PART: C TYPE: 47uF/25 QTY: 1 SUPPLIER: Farnell PART No: 920502
PART: C TYPE: 220uF/35 QTY: 1 SUPPLIER: Farnell PART No: 667420
PART: C (swr br.) TYPE: 22nF/250V QTY: 2 SUPPLIER: Farnell PART No: 3038075
PART: RX filter C TYPE: 2n2 QTY: 2 SUPPLIER: Farnell PART No: 3038075
PART: RX filter C TYPE: 56pF QTY: 1 SUPPLIER: Farnell PART No: 105886
PART: RX filter C TYPE: 20nF QTY: 1 SUPPLIER: Farnell PART No: 568223
PART: C TYPE: 1nF QTY: 1 SUPPLIER: Farnell PART No: 635147
PART: Case TYPE: 95x125x220 QTY: 1 SUPPLIER: Farnell PART No: 518876
PART: TX Filter Cs TYPE: 10nF/1.6kV QTY: 2 SUPPLIER: Farnell PART No: 577832
PART: TX Filter Cs TYPE: 22nF/1.5kV QTY: 1 SUPPLIER: Farnell PART No: 106371
PART: TX Filter Cs TYPE: 2n2/2kV QTY: 3 SUPPLIER: Farnell PART No: 577819
PART: TX Filter Cs TYPE: 4n7/2kV QTY: 4 SUPPLIER: Farnell PART No: 577820
PART: R for Zobel TYPE: 22R 25W QTY: 1 SUPPLIER: Farnell PART No: 345090
PART: Trim C TYPE: 60pF QTY: 1 SUPPLIER: Farnell PART No: 303872
PART: C in parallel TYPE: 47pF QTY: 1 (10) SUPPLIER: Farnell PART No: 498312
PART: Decouple C TYPE: 2u2/250V QTY: 1 SUPPLIER: Farnell PART No: 148896
PART: Mains trans TYPE: 2x35V 530W QTY: 1 SUPPLIER: Farnell PART No: 177945
PART: T1 TYPE: 58mm QTY: 1 SUPPLIER: Arrow PART No: 420605G
PART: CH1 TYPE: Ferrite rod QTY: 1 SUPPLIER: Arrow PART No: 409653X
PART: T2,T3 TYPE: Toko QTY: 2 SUPPLIER: Bonex PART No: 719VXAA017AO
PART: T4, Ferrite TYPE: Tube 15x11 QTY: 1 SUPPLIER: Maplin PART No: AN78K
PART: Filter cores TYPE: T2002 QTY: 2 SUPPLIER: Mainline PART No: T2002
PART: Alternative TYPE: T2002 QTY: 2 SUPPLIER: Bonex PART No: T2002
PART: Meter TYPE: 0.25mA FSD QTY: 2 SUPPLIER: Maplin PART No: LB80B
Parts list.
