Hi everyone,
I am relatively new to electronics, but I have to build a µC based circuit, which will select the power source (one of two 36V Li-Ion batteries) for the ebike controller. I have come up with the circuit below, but I am not sure if this will work. I know that these batteries are dangerous, so I will probably implement ideal diodes on the high sides. What I am not sure about is, if the n-channel mosfets (Nexperia Buk962r5-60e) will operate with the the shared GND between the batteries. I haven't determined all of the values yet, as I need to know, if I am on the right path.
There should only be one batterie attached at all times !
Details:
3.3 Buck Converter
Nexperia Buk962r5-60e LL n-channel
Teensy 3.2
Thanks guys !
Details:
3.3 Buck Converter
Teensy 3.2
Thanks guys !
