Hello, I am wanting to design and fabricate a high voltage supply using the MC34063 to power Nixie tubes for a clock. Currently I am referencing this site for a circuit
https://andrewjkramer.net/usb-nixie-power-supply/
When modeling this circuit in LTSpice, I can’t get the 170 volts on the output. Instead it is just clamping to about 11 volts on the steady state. Is this a circuit issue, or is this an LTSpice issue? Just trying to make sure before I order parts for it that this circuit works for the build.
I will attach the LTSpice files below.
