Ubuntu 22.04 wont boot stuck in ( initramfs) after updates .
frank55
Joined Dec 6, 2013
314
Hi folks , i installed Win10 in 1 HDD and Unbuntu 22.04 in other HDD and installed Grub manager ,it has been working fine till i installed new updates. now it wont boot and doesn't make recovery either and stuck on initramfs ,i type blkid and get this see pic attac. bellow ,althou it boot in Win10 .Any help will be apreciated .
Can you do a Linux USB/CD live recovery boot and chroot to the Linux partition from the shell?
https://askubuntu.com/questions/123...4-please-update-the-microcode/1238393#1238393
Thanks, my bad i had installed Ubuntu 24.04 and not 22.04 i did not do any upgrade , i installed updates from popped up ubuntu suggestion.
It doesn't matter what version. The possible recovery procedure is the same. I've never liked dual booting systems but I know it's a necessary thing.
Looks like there is a tool to help.
https://help.ubuntu.com/community/Boot-Repair
I don't run Ubuntu but I still run stock Debian on a few machines for Home Assistant and the rest run: https://en.wikipedia.org/wiki/Devuan
because I hate systemd.
frank55
Joined Dec 6, 2013
314
Well i gave up and back to Win 10 only .If in the future i have issues with Win 10,. I will install Ubuntu.
frank55
Joined Dec 6, 2013
314
Why? Did you follow @nsaspook's recommendation? What happened?
No; everything was find the way i did . I had 2 HDD 1 Disq 0 win10 the other Disq 2 Linux and grub manager and DVD drive . What i found out was that i was running in the Bios HDE instead of AHCI which i corrected by reinstalling Win but this time i only kept 1 HDD with win10 for now,that is a keeper till i get issues due no support cause i have some prog that only run in Win.
joeyd999
Joined Jun 6, 2011
6,456
Is VMs free?
VirtualBox is free as in freedom (and also as in beer) except for the Extension Pack*.
There are certainly other VMs that are also free, but I don't use them so I cannot advise.
You still need a valid license for the Windows installation(s).
*Edit: The Extension Pack is free (as in beer) for personal and educational use.
