U/I converter
Falco1
Joined Apr 29, 2017
5
I need output current ~10 uA-30 mA and input voltage should be 0-5 V. I can build U/I converter with an op-amp and 150-ohm resistor, but it means that I get 10 uA for 1 mV.
Is there an easy way to get 10 uA on the higher value of input voltage (e.g. 100 mV)? For example some nonlinear element, or threshold. Because 1mV is a small value.
Thanks in advance for any suggest
Papabravo
Joined Feb 24, 2006
22,111
I don't know if you can do it with a single device. Your range covers about 2.5 decades. I'm thinking it might require some kind parallel control with a coarse and a fine adjustment. Non-linear will probably not work well. As you may or may not know adjusting anything non-linear is more than a bit tricky.
Alec_t
Joined Sep 17, 2013
15,156
Here's a non-linear approach, but it would not be very consistent/reproducible, because of the temperature dependence of the diode response. The two yellow traces are for 0C and 30C respectively.
