Two wireless devices with coaxial cable
ivars211
Joined May 5, 2013
20
Might be really dumb question, but just curios. (couldn't find anything useful).
Let's say I have two wireless devices, both have SMA connectors for external antenna. Can I connect them both with some form of coaxial cable together? Would they still work for like 100m, or would the signal be too week?
BR-549
Joined Sep 22, 2013
4,928
Coax is an attenuator. The amount of attenuation depends on coax type, frequency and length.
A length of coax can make an excellent dummy load.
Depending on that frequency and power level, you probably can't get a signal thru 100 ' of coax.
ivars211
Joined May 5, 2013
20
I am thinking of RFM69HW 868Mhz on both ends (tx @ +20dBm). 100m RG6 @ 868 has attenuation of 20dBm. I guess that's still too much power for receiver end?
AlbertHall
Joined Jun 4, 2014
12,663
If you haven't got a spec for the receiver max input power it's difficult to say for certain. 0dBm may well be OK - it's not going to damage anything so you can try it and it's easy enough to add some a couple of resistors to reduce it if need be.
