The Electrician
- Joined Oct 9, 2007
- 2,970
newbie2019, are you still working on this?
Yes dude.newbie2019, are you still working on this?
I think that I have the dc analysis of the two-stage amplifier with and without negative feedbackWhere are you in the process? What are you trying to do now?
no..please teach usDo you know any of a circuit/network analysis techniques?
https://www.allaboutcircuits.com/textbook/direct-current/chpt-10/what-is-network-analysis/no..please teach us
Do you know any of a circuit/network analysis techniques?The last part of my study involves computing the ac voltages and currents for
the configuration with negative feedback.
First I had the circuit with no feedback and I was able to analyze the ac current and voltages.https://www.allaboutcircuits.com/textbook/direct-current/chpt-10/what-is-network-analysis/
Also, what is the point of doing all those analyze and find AOL and ACL. If now you want to solve the circuit with the negative feedback directly? Without involving the "feedback theory" (without AOL ACL and feedback factor)?
We use a feedback theory to get approximation result without the need for direct analysis of a whole circuit.
You and newbie2019 are apparently using the same text book. Have you learned standard network analysis techniques, such as nodal, mesh, loop?no..please teach us
nope..don't have his textbookYou and newbie2019 are apparently using the same text book. Have you learned standard network analysis techniques, such as nodal, mesh, loop?
Are required to use some particular technique to analyze your circuit, such as with concepts like loop gain, factors like Av / (1 + (Av * β)), etc., or can you use any technique you choose?First I had the circuit with no feedback and I was able to analyze the ac current and voltages.
Now that I have the same circuit but with negative feedback, the ac currents and voltages are different.
If I didn't have LTSpice how would I predict these new currents and voltages?
@newbie2019Are required to use some particular technique to analyze your circuit, such as with concepts like loop gain, factors like Av / (1 + (Av * β)), etc., or can you use any technique you choose?
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Jake Hertz
