The TS was very clear, if either switch is ON, the light is on.I think the TS is more concerned about the physical ON OFF indication of the switches. If a switch is in the OFF position then the light should be off and visa versa. You lose that functionality when you have two switches controlling one light, with one power source or two.
Yes that's the whole point. It's more important to me that the lights stay on when I need them to be on.If the light is on when both switches are on. How do you turn the light off? You need to turn both switches off.
Not in this case since the second switch is remote-operated.If the switches are far apart you will be doing more walking than switching.
I'm not worried about the physical indicators; not least because the second switch doesn't have a physical on/off indicator.I think the TS is more concerned about the physical ON OFF indication of the switches. If a switch is in the OFF position then the light should be off and visa versa. You lose that functionality when you have two switches controlling one light, with one power source or two.
Thanks Bob!The safe way to do it is to have one source switch a relay that is parallel to the other switch.
Bob
My first thoughts too. Not to mention, if you DO get a dead short at 240 VAC - you're going to get a lot of excitement the moment both switches are switched on. So far this is all speculation. There's a lot we don't know.Only if they are from the same split-phase from the transformer (in the US).
If they are from opposite phases, you will get a nice dead-short across the 240.
This is new information.the second switch is remote-operated.
