Two positive input to one positive input
Ping pong
Joined Feb 13, 2022
91
So I have bought a pair of LEDs that are connected to a timed delay relay and the signal for it is coming from the cars positive ACC wire. When the ACC gets power, it triggers the relay to turn on the LEDs. When the ACC loses power, the relay deactivates after 15 seconds (hence the delay relay)
But now, what I want is that when I unlock the car, that also acts as a trigger and turn on the led. I already know where I'm going to get the positive wire for that so that isn't a problem. The problem is how I'll connect it and make it all work.
Like I could simply connect the trigger wire for unlocking with ACC and call it a day. But that'll probably short something and burn the car.
So there must be some other relay or device that I could use which keeps both ignition and unlocking wires disconnected and sends signal from one or the other depending on which one has power.
I am pretty noob at this kinda stuff so please bear with me.
Ping pong
Joined Feb 13, 2022
91
Thank you for your reply. I have just two questions.
Will this be able to handle 12volts and what would happen when both inputs have current.
Ping pong
Joined Feb 13, 2022
91
Great, that was quite helpful.
So can I connect more than two diodes considering I want there to be more than two signal wires, each from a different source.
sghioto
Joined Dec 31, 2017
8,747
An offshoot question.
How can I replace the diodes with FET's in this setup? I have seen FET's used in Reverse Polarity Protection but not for this configuration.
Tks.
Why would you want to when a diode is all you need.
Not sure if I'm following you correctly, can you elaborate on this?
Ping pong
Joined Feb 13, 2022
91
So what I have read on the internet, the 1n400x diodes are rated for max 1A. Is that suitable for my use or should I get a volt meter and check the amperage from the wires.
Considering the it is greater than 1A, what should I do?
Ping pong
Joined Feb 13, 2022
91
https://a.aliexpress.com/_mq7ZW2s
This is the led bulb that I'm using. The amber part is connected to the factory turn signal plug, however, the white led will be getting power from the relay which will be getting power straight from the car battery.
Could you please tell me what amp fuse should I use for the white leds. They draw 12v 0.5A according to manufacturer.
