Two-Pole Passive RL filter
Efexynoob
Joined Sep 5, 2023
A bit new to passive filters, so wondering what is the formula of frequency cutoff for the two pole Low Pass RL filter? And how Gain/Frequency graph would look like? Thank you! RDT_20230905_0806246720477943089937920.png
38,737
The interaction between the two stages can be reduced if the impedance of the second stage is made ten times the impedance of the first stage.
Ian0
Joined Aug 7, 2020
13,248
The second RL loads down the first RL causing a VERY droopy response.
An equal-value RCRC filter has a Q of 0.333. I suspect an RLRL would be the same.
The best Q you can achieve is 0.5 (critically damped), where the impedance if the second part is >10 times that of the first.
38,737
Below is the LTspice sim of two cascaded RC filters, showing the difference for them being equal, and the second having 10 times the first impedance:
The equal filter is about 6dB down at 1kHz while the other is about 3db down, with their high frequency rolloffs being nearly the same.
Ian0
Joined Aug 7, 2020
13,248
RCRC filters are really useful - you can achieve 12dB/octave roll-off, there is no overshoot or ringing, no problems with pickup in inductors (or getting inductors of high enough inductance) and no problems with op-amp phase-shift at high frequency spoiling the attenuation. The low Q is the only drawback.
Efexynoob
Joined Sep 5, 2023
Everyones graphs are similar, I appreciate the help, but still a bit confused about Cut Off frequency... when calculating by the hand getting around 80Hz, when you guys and other forum people get about 47Hz. Formulas I'm using:
