Two motion sensors, one 12V LED strip
Ya’akov
Joined Jan 27, 2019
10,297
Just a point about motion sensors pressed into service as occupancy sensors.
PIR and other motion sensors require motion (no surprise) to detect the presence of what might be a human occupant. Since people often stop moving after they arrive in an area, the timeout included in the sensor will elapse, and the light (or other device) will turn off.
This is because a motion sensor is not an occupancy sensor, it's just used in place of one. A true occupancy sensor is not a trivial undertaking and until recently, faking one with a PIR or similar was probably the best we could do. But recently (last year or so) there have been some pretty impressive developments combining increasingly capable edge computing using MCUs with FMCW Radar.
The result is a range of cheap modules that are actually capable of acting as true presence sensors. This blog post covers the basics, but things have developed since them with even more variety and lower cost. If you are looking for a presence sensor, forget PIRs and look at these modules instead.
TogetherInElectricDreams
Joined Jan 23, 2019
242
Correct more amps. At 10 watts per meter x 5 meters = 50 watts / 12 volts = 4.2 amps.
Power supply rated 6 amps or more will suffice, something like this
So I've seen 6 amp transformers but there's a 5 amp one that's nearly half the price. Is that too close to my needs? Is it safer to get the 6A or will the 5 suffice?
sghioto
Joined Dec 31, 2017
8,751
5 amp is 20 % more than required so I would think OK as the LEDs are only on for a short time correct?
Post a link to this supply please.
Joined Jan 23, 2019
242
Joined Jan 23, 2019
242
That supply is rated 6 amps, is that the one you want?
It is? It says
Retoo LED Power Supply Power Adapter 12 V Transformer DC Maximum Power Supply for LED Strip 5A Stripe Charger Adapter Power Supply Driver Converter EU Plug Black
But if it's actually 6 amps then that's all good. Also, I forgot to ask, how am I wiring this up with two motion sensors please?
Joined Jan 23, 2019
242
Thank you and great find on the adaptors! I didn't see this deal so I've snapped them up. Thank you. I'll be in touch soon about the other LED thing and also to let you know how this went. Should have it up and running by the end of the week.
Joined Jan 23, 2019
242
Besides cutting and splicing cables use Adaptors wired like this:
Dear Sghioto, unfortunately this isn't working, partly because I don't have the flexibility to use these adapators with everything.
My power source has a male connector, my motion sensors have two jacks, out which is a male jack and in which is female. My LED strip has a male jack at one end and pig tails (red and black wires) which could be wired into this adaptor. I also have a female/female adaptor as I thought that might be necessary and by the way the PIRs don't have a power connector (I assume you mean the input?)
I tried to wire this up with the motion sensors as shown here (connected the outputs with the female, female adaptor) and all that happened was, was that the lights came on. The motion sensors did nothing, I covered them to be sure.
Do you mind helping me a bit more? Thank you.
Joined Jan 23, 2019
242
Post photos of the actual components you have on hand.
Need to see power supply, PIR and LED wires and/or connectors.
Thanks Sghioto, I think I've solved it. I am using a splitter from the power source and powering the LED strip from either end of the strip via the sensors. Seems to be working! :) I'll fit it up finally tomorrow and report back. Appreciate your help.
Joined Jan 23, 2019
242
Hello everyone, I just wanted to say that I managed to get this working with two motion sensors and I am very happy with how it's turned out. I appreciate all of your input in getting this up and running. Have a wonderful Christmas and New Year :)
