Two diodes used with 1 relay
nitinsharmaece
Joined Jun 27, 2012
1
I want to know why sometimes 2 diodes are used with relay, despite 1 is enough for safety purpose.... Also tell me the applications where 2 diodes are used ??:rolleyes:
absf
Joined Dec 29, 2010
1,968
I only know that there is only one diode connected across the relay coil to prevent back emf that would destroy the driving transistor. Where is the second diode connected?
Allen
18,183
Using two would increase the amperage than can be handled without finding a new part with a higher rating. Just speculating
38,936
Two diodes in series can be placed across the coil for increased reliability. If one diode shorts, the other still works, allowing the relay to continue to function.
ErnieM
Joined Apr 24, 2011
8,415
If so, it may be to speed up the release of the relay as described here: http://relays.te.com/appnotes/app_pdfs/13c3264.pdf
John from the Great State of Texas nailed it!
I have the inside track on that: I just designed the coil suppression network for "a major relay manufacturer" (which may or may not be TE) and this describes it's function exactly. Basically it's just a zener and a diode on a .1x.22" board and two fly leads.
They put our part inside their relay, actually wrap it over the coil.
One thing to note is the zener voltage ADDS to the applied voltage during turn off, so don't be stingy with the controlling element's voltage rating.
