Tweaked LM3914 circuit. Will it work ?
Externet
Joined Nov 29, 2005
2,638
Hi.
There is only 5 LEDs wanted in this circuit, to display on a range of 1.2 to 7.6V input.
Some output pins are paralleled to the same LED. Is that allowed ?
Is this an acceptable way to set range limits ?
38,534
Yes, since the outputs sink current, you can parallel the outputs in the DOT mode. It just means that the top and bottom LEDs will remain lit for all input voltages above/below their respective trip points.
DeciBel forever!
