TVS protection required ?
fastbike
Joined Dec 29, 2020
128
I'm designing a controller with an op amp output (at a nominal 0 to 10v DC) that will be connected off the circuit board to a dimmer. This will be installed in a mains voltage DIN rail cabinet (230V AC environment).
Do I need to add a TVS diode to the output to protect against transients ? Something a bit like PESDxL1BA ?
I think I'm kind of answering my own questions even as I type, but some confirmation would be handy.
28,125
If the dimmer is the type designed to be controlled by a zero to ten volt signal, and if the connection will be of a permanent nature, not subject to random disconnection, then there is no need for a separate TVS protection device.
Otherwise, a simple pair of clamp diodes to prevent the opamp output from receiving a voltage above the opamp V+ or below it's V-, along with a 100 ohm series resistor, is all that you need.
fastbike
Joined Dec 29, 2020
128
Yes, the connection will be permanent once installed. I'll take a look at using steering diodes as suggested
