Turn on/off LED with Limit Switch
azhan
Joined Feb 2, 2017
Hi All,
I wanted to do a simple circuit whereby a LED can be turn on & off using contact limit switch.
Question 1
I've connected like below image, why the battery become HOT? does it because I did not connect any ground?
Question 2
Where do I put the LED Anod & Catod if I wanted to make the LED on when the switch is closed?
ericgibbs
Joined Jan 29, 2010
21,589
Hi azhan,
Without a resistor, the battery will get HOT!
Look at this modified circuit.
The resistor value will depend upon the LED type, what LED do you want to use,?
E
azhan
Joined Feb 2, 2017
Hi azhan,
E
Hi eric,
I dont have the LED details but it requires 3V as what the shop says and the LED diameter is 10mm
what resistor should I get?
ericgibbs
Joined Jan 29, 2010
21,589
hi,
Driving a 3v LED from a 3v battery will not give the result you expect.
Even though the LED has typical 3v forward voltage drop, they can have a voltage range of +/-10%
Also the battery will discharge below 3v when on load.
What is the specified operating current of the 10mm dia LED.? and the type of battery.?
E
ScottWang
Joined Aug 23, 2012
7,505
You have to modify the wiring first.
The function of Pins of limit switch:
1. N.C - Normal Close
2. N.O - Normal Open
3. COM - Common pin
Question 2
The COM pin connected with N.C pin and then they are in the shorted situation, so you should exchange the pin N.O an N.C.
You could use the circuit as ericgibbs provided, but you have to exchange the the pin N.O an N.C.
3V/10mm led then current could be 10mA, 3V battery to a 3V led is not a common method to use, but you can try a 10Ω 1/4w resistor to protects the led, if it can light up the led then you can try to using the bigger resistor, adjust the value of resistor and brightness, until you get satisfaction.
