The attached schematic is the power supply portion of a larger project. The active component is a DC-DC converter that puts out +5 and -5v DC and a ground reference (COM). These voltages are tapped at the indicated +5V and -5V points to run the rest of the project. The +5v and COM outputs of the converter are also connected to a USB cable that can plug into and power an external device drawing 100mA through the V+ and V- termination points on the far right of the schematic. When the external device is not connected, there is no current flowing between these two termination points.
I would like to figure out a way to turn on an LED when current is flowing to the external device (i.e., between the V+ and V- termination points) but I cannot put the LED in series with the load because I need the full 5 volts (or close to it) to power the external device, and, of course, an LED can't take 100mA through it. Is there some kind of active device that could be put in series with the load and not drop the voltage (much) but would produce a signal when current is flowing through it? Or some other way to accomplish the goal?
Thanks,
Mac
