Saw that coming a million miles away. I'm 33, and I'm a big boy. I came here to learn, not to be talked to like a child.If it's that difficult for you to connect one transformer, one thermostat switch, and one relay, you shouldn't be playing with electricity. Buy the baseboard heater thermostat with a baseboard heater wrapped around it and quit trying to see if you can die in a house fire.
You simply can't run away from your problems, just because you don't understand something, or have a bad experience with something.
Geesh.. Could you imagine if everyone did that.. Just took the easy way out?
Nope.. The moons too far away, too cold, and there's no oxygen in space, it's a bad idea guys, let's not send a man to the moon.
I think we would be a pretty pathetic race if everyone did that.
My problem is that I simply don't understand the relay, even when I look at the data sheet.
Here's the relay data sheet.. I don't understand it. I don't see anything about the contacts, or which contact does what.
655-K10P-11AT1-24
Is this the configuration? I don't understand it.
