Ok I am building a Factory Five MK4 Roadster for a private individual and its the base kit so there for we used a Donor Car for certain parts, our donor car is a 2001 Mustang SVT Cobra. Ok here is my on going dilemma or I should say nightmare, instead of trying to figure out the mustang flasher circuit we opted to make my own harness or circuit both I guess. Anyway long story short I have taken apart and have rebuilt the part of the harness were it all meets at the column, I have 4 wires (RR,RF,LR,LF), a three post flasher (34), and four diodes (4x1N4001), ok so I have everything working properly but here is the kicker the flasher will not stop clicking. Oh yeah the column js a simple Russ Thompson column it has 6 wires two for the high beam switch (which works great) and a black/white w/green then Black/White (Left Turn), DG/BLK (Right Turn). I have taken the column apart searched for bad wires, I have done everything that I can think it could be. Today I took the wire which is connected to the turn indicator switch on the column off of the flasher and then I touch that same terminal with a test light and it started to click the same way when its connected to the column, mind you that while its doing this the lights don't flash until you flip the lever either direction that you would normally do. I will attach a copy of the schematic that I used so please if anyone has any inkling to what I did or am doing wrong here cause I should be a lot farther with progress than I am and its because of this stupid and I'm sure very simple problem. Thanks for your time and for reading this, any input will be much appreciated...
