I have been working on a circuit to turn a motor on for several seconds, and then off for a longer period, using a 555 astable circuit. The on time needs to be around 5-10 seconds, and the off time needs to be about a minute. To get around the 50% duty cycle issue and allow for a longer off period, I put a signal switching 1N4148 diode across R2 of the timing control part of the astable circuit. I haven't tested this, and if anyone can see a glaring issue with what I have, input would be appreciated.
I then realised I might have another problem - this circuit is going to continuously drive the motor despite the timing, because the motor doesn't care about polarity. I came across the possibility of using a 5V relay coil to turn the motor on/off based on the drive circuit transistor coming from the 555 timer output I already had, but I am unsure how I connect the motor to this to achieve what I want, as most online examples show the motor having its own separate power supply, which I cannot do as the motor needs to be powered by the same supply as the 555 timer circuit. Basically, how do I get the motor to turn on and off using the timer circuit I have, and if I need the relay, how do I connect it with the 6V motor? My diagram is below. I have limited and rusty knowledge of circuit design, so explanations would be appreciated.
