tube light choke
i need circuit ( schematic ) for tube light choke
  • vi
    Votes: 0 0.0%
  • acc
    Votes: 0 0.0%
  • Total voters
    0
shashank sharma
Joined Mar 18, 2015
4
I think you need to explain clearly just what a 'tube light choke' is.
The main function of Choke in tube light ckt is to boosting the voltage level & starter has nothing but a simple bi metallic strip inside which closes & opens the ckt.when we switch the ckt current flow in side Choke,starter & tube filament.when the voltage level increase nearly 10 time the normal voltage its heat the filament .as a result current passes through tube light directly with the help of argon gas & starter is automatically cut off from ckt
Alec_t
Joined Sep 17, 2013
15,163
i need a software to draw schematic by watching an actual circuit
That would be very useful! All you'd need to do would be photograph top and bottom of a populated PCB, import the images into the software, let it reverse-engineer the circuit, then spit out a schematic. If you can identify a source of this software I'd be interested to know.
Or have I misunderstood your requirement?
