Tube experiment: What do they require to operate?
Lectraplayer
Joined Jan 2, 2015
123
I am wanting to experiment with the small signal characteristics of a few vacuum tubes I have laying about (and I have many) sort of in a guitar amp or home audio type of role, and am wondering about what the lowest voltage one typically can operate well at. Both my input and output signals are expected to be "line level" (-10dBm, and less than a volt
%s" type="text">
peak to peak) and with near unity to double gain, although gain may be left unchecked at times.
...or to put it another way: can I operate a tube off of 12V DC plate to cathode, or will it require nearly a full 120V DC to work well?
The purpose of this circuit will be to experiment with things like how adjusting bias and even heater temp will affect the "sound" of a tube. May even aid in tube selection at times. It is intentionally quick and dirty.
LesJones
Joined Jan 8, 2017
4,530
Most valves (Vacume tube) need a higher voltage on the anode, I think around the early 1960s there was a range of valves designed for use in car radios that worked with 12 volts on the anode. I can't remember the numbers of any of these valves. The output stage used a single power transistor such as an OC28.
Les.
Reloadron
Joined Jan 15, 2015
7,921
Depends on the tube or valve in question. I have an old military R392 receiver which uses a 28 VDC plate voltage. I also remember old 6V and 12V car radios of the 50s which used a vibrator & transformer to make HV AC to be rectified to HVDC as the plate voltage for the tubes. Tubes, like transistors have data sheets and many of those data sheets can be found online. For example, a popular guitar audio amp was the 6L6 and here is the data sheet,
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,776
As well as a DC supply, you also require a low voltage supply for the cathode heater.
Many of the low voltage (12v) anode types were preceded by 12 as in 12AF6.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,776
In fact the origin for the odd ball voltages of 6.3 & 12.6 originates from the original tube equipment filaments being fed from lead-acid 'accumulators' who's fully charged voltage resulted in these values.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,776
I have a 1966 version of 'Radio Valve Data' for over 7000 valves and semi conductors from valve manufacturers of the time.
These have all the detailed characteristics listed for each valve.
Max.
