tube amp-leave it on or turn it off
leon23
Joined Oct 11, 2008
22
I have a Marshall guitar tube amp. I'm wondering if turning it off and on several times during the day stresses the tubes more than just leaving it on all day.
38,721
A good compromise is to put the filaments at half power in a standby mode when the amp is not used.
That allows the amp to come on rapidly when full power is applied, but there is much less thermal shock to the filaments, which is likely what causes filaments to fail sooner.
Depending upon the design, using a DPST (or DPDT) switch to connect a power resistor of the appropriate value in series with the filament power, and also switch off the plate voltage, would do that.
ian field
Joined Oct 27, 2012
6,536
In TV sets with heater chains; some manufacturers put a rectifier across the on/off switch, pointing the opposite way to the HT rectifier. That tactic was defeated in later models because manufacturers found they could reduce the dropper resistors by half-wave rectifying the heater supply.
Valves take the biggest hit from switching on from cold, the heaters draw more current when cold and the turn on surge is a lot of stress. NTC thermistors were common in heater chains, but not very practical on all parallel heaters.
The best solution is switching over to a lower voltage standby heater transformer, maybe 4.5 - 5V or so - you'd have to also kill the HT or it'll strip the cathodes.
Lestraveled
Joined May 19, 2014
1,946
Hi, ex bass player here.
First I doubt that the TS wants to modify his amp. Modified amps are worth less than pristine ones.
Doesn't your amp have a standby switch? (This switch turns off the high voltage but leaves the filaments on.)
Regardless, tubes have a finite life, but they are easy to replace. You have to re-tube an amp every so often anyway. Leaving your amp on all day just consumes the filament life. Just use good judgment about when it is going to be used and turn it off.
leon23
Joined Oct 11, 2008
22
All great answers. Yes the Marshall JCM900 has a heater switch. I always turn that switch on first but I don't leave it on long enough before turning on the main power. I got no help from the Marshall forum or from the lady receptionist there who apparently they have put in charge of answering tech questions.
Kermit2
Joined Feb 5, 2010
4,159
Tube amps are increasingly popular, so the price of the common tube will continue to fall as suppliers fight to win market share.
Yes, you can extend the lifetime of a tube by using standby heater techniques, but the amount of savings is hard to value and the tube are currently cheap enough to not be a problem for an employeed individual.
leon23
Joined Oct 11, 2008
22
Somewhere I read that when you put in new tubes you have to tweak/adjust the circuits somehow and that this is something a professional should do. ?
ian field
Joined Oct 27, 2012
6,536
Sometimes in RF/IF circuits, manufacturing tolerances cause slight variations in electrode capacitance that can take the tuning off trim.
With audio power stages its not a bad idea to make sure the plate current is within spec, sometimes you have to tweak the bias.
Its never a bad idea to check any capacitors in C/R coupled stages - especially if the previous bottles imitated electric fires.
Even slight leakage can wipe out the negative bias on the grids and cause excessive plate current - full on HT from the previous stage can destroy the grid, then your expensive beam-tetrode is just a rectifier diode shunting the HT.
