I hope this isn't true.Since the bridge will reverse the polarity to the motors to obtain the two directions, then you are shorting the output with your diodes. You cannot use diodes as clamp connected in that way. You will burn the controller and your motors will never move! Use a RC filter connected in parrallel to the motors! And remove all diodes!
I did it the same way they did it in the data sheet, the only difference is that the data sheet used stepper motors.
I can't really change it now - I've got a PCB on the way.
Oh well. I guess that's one mistake I'll never make again.
