Trying to make a 50ohm 7Mhz antenna
SamR
Joined Mar 19, 2019
5,526
Seems they left one small detail off. Typically, the dummy load can is filled with mineral oil as a heat adsorber. Which also requires a small vent in the can's lid for expansion venting. Can be as simple as thumbtack through the top of the lid with the inserted end bent so that the thumbtack is retained from falling out. That will keep any dust or grime from contaminating the oil and allow expansion without blowing the lid off the can. Also known as a Cantenna.
Alec_t
Joined Sep 17, 2013
15,149
I'm saying that if I had a smaller antenna I would only transmit up to a certain distance? Is that right?
No. Radio waves will propagate unobstructed over an unlimited distance, but get weaker as they do so.
